Angled brickwork
5 Jun 2019
Looking for some ideas on building these two corners. As the customer doesn't want a birdsmouth. Am I looking at running a straight joint right up with ties in it??
Use cut and bonded brick,your merchant can order these using your face brick, make a template to suit.
Straight joints look shoddy.
Lol, you're the builder and you had to ask for the options? :cautious:
That's nearly as bad as the designer designing it like it in the first place, and not specifying it.
Cheers for the replys (apart from woody :oops:) I never even gave making angles myself a thought to be honest .
Is it simple enough to do the epoxying I've never had to do it before.??
Aye the architects drawings are pretty vague. (y)
The cuts need to be really accurate to make them yourself. You need a clipper rather than an angle grinder. The acute angle might present a few problems.
Aye Stuart it was that one I thought I was gonna have the most bother with. I've got access to a clipper so that's no an issue just never had to do it before so no wanting to make a pigs ear of it.
It hasn't got a straight joint, looks better than OP first idea.
I would use cut and bonded by specialist about £5 each, the sharp angle as Stuart says would be awkward to do yourself.
Straight joint
Straight joint
I know what a straight joint is and I can see a straight joint in the other picture you posted :confused:
Ideally, external angle bricks as shown in your earlier photo are the answer.
The picture was for original poster to see how awful it looks,and thats quite a decent example.
The universal brick was just another option ,never used them but have seen them in an extension i always pass and they suit that building perfect,due to the original brick features.
They don't have a straight joint as such, but like we all agree first choice is bonded brick.
images
UJ's are quite popular on sites nowadays, as the angle is easily adjusted to suit. Some people think they look good. Any of the methods require a lot of care lining up the corner. Using a plumbline helps a lot if you can set one up.
Thank you, I have worked on jobs with some quite fancy brickwork features but I must admit I was not familiar with that universal brick corner detail.
I see what you mean about the 'vertical joint'. Like you suggest it would need some particular brickwork features on the existing building for that not to stand out like a sore thumb on a new extension.
images
Cheers for all the replys lads got in touch with the architect and he's gonna price up getting cut and bonded bricks made.
I wouldn't call that a decent example of a straight joint . Pretty confident I could do a much tidier job of running a straight joint so it wouldn't stick oot like that.
