- Joined
- 25 Oct 2019
- Messages
- 4
- Reaction score
- 1
- Country
Hi, just looking for some advice on permitted development rules and how they apply to a previously extended property.
I am looking at doing a hip to gable loft conversion with a rear dormer. The house is a 1930s semi and has already had a two storey side extension with the roof on the extension being stepped down to half the height of the original roof. Two architects have told me that because of the previous extension I would need planning permission and would be unlikely to get it for the dormer, but I am not convinced that is correct.
The plan would be to do the hip to gable conversion over the original external wall leaving the roof over the extension sloping up to the new gable end.
There are a couple of picture attached that I hope will make it a little clearer.
My understanding of the PD rules is that as long as the volume of the resultant external roof space isn’t increased by over 50 cubic meters when compared to the original roof (plus a few other conditions) then it falls under PD.
When calculating the additional volume I believe I can simply take the additional volume created by the dormer and new gable end vs the original roof and add on just the part of the existing extension roof that remains outside.
I assume I don’t need to include the additional roof space on the existing conservatory.
Based on my measurements, this would result in a total increased volume right on the PD limits, but I am confident that I can tweak the size of the dormer sufficiently to get it under the limits and would apply for a certificate of lawful development.
I am just a little concerned that two architects would fail to advise that that would be the case and suggest that full planning would be necessary.
Any advice would be gratefully received.
Thanks in advance.
Thanks in advance.
