Hi.... A few days ago I noticed that my 2006 Vectra C had developed a high pitched whine (sounds a bit like a car reversing fast or a milk float). My first thoughts were that it was the gearbox but following some online searches the alternator kept cropping up as a possible culprit.
Strangely, the noise only happens when accelerating and seems to be most noticeable between 1000 rpm to 2000 rpm. It's slightly noticeable in 1st and 4th gears but loudest in 2nd and 3rd gear.
If I press the clutch pedal it stops (which is why I first thought gearbox) but I've noticed that it also stops if I take my foot off the accelerator.
If I am going downhill with the car in gear, doing the same engine revs (say 1500 rpm), same speed etc. wouldn't the gearbox still be turning the same as if I were accelerating on a level road ? and so should make the same noise if it was a gearbox issue. But the noise stops in this situation.
Can anyone confirm my thoughts or correct me ?
