But they won't fit in a 5a fused plug. The fuses for those are smaller approx 20 x 5mm.
the linked to ones were standard 1 in fuses
2, 3, 13, and 15 amp British plugs all have the same wiring orientation, so line on the right, neutral on left and earth on top.
Thanks @Tigercubrider and @sparkwright
And I'm sure it's not rocket science, but despite my googling and youtubing, I can't actually find a simple video or instructions for replacing a 13A plug with a 5A one?!
My dad did so much electrical work I reckon I could wire a plug before I was at school and yes we were taught it, including my sister at an all girl school.How times have changed. I learnt how to change plugs at school.
The vast majority of 5A plugs have no fuse at all.Since the priority is to plug the lamps into the 5amp sockets, I would suggest removing the 13amp plugs and fit 5amp plugs (modern 5amp plugs have a small 5amp fuse fitted, older 5amp plugs have no fuse at all).
MK do make a 5A plug with a BS646 fuse (5A by default but lower ratings are available), but it's rather expensive and (unlike most other brands) the MK round pin plugs do not have pin insulation. So it's a tossup which is safer, MK with a fuse but not pin insulation or another brand with pin insulation but no fuse.
