I'd like to buy a table saw and use it in my garage for light woodworking projects. The garage is maybe 15-20 metres from the house and I believe everything goes through the RCD. The house and garage were built in the mid 60's. In the garage there is only one double socket and some LED light battens.
I currently have a compound mitre saw and the lights will blip when it hard starts, perhaps this is to be expected?
I have no idea what diameter the cable is from the house to the garage - is there a way I can check that I'm OK operating a table saw (1800W) and perhaps a dust extractor (1200W) simultaneously? I wouldn't be using anything else in the garage at the same time other than the lights though may of course have the oven on or boil the kettle in the house. At maybe 3kW I believe that's around 13 amps but maybe it can peak a lot higher when they both start up.
If it's not OK, I'm not sure what people do - get someone to run a bigger underground cable?!
