Hi all
First post here! Hoping you can help sort my loft space out. I have read several threads already including CONDENSATION IN LOFT (ANSWERS) - none quite answer my questions!
I have a Victorian semi-detached house with a slate roof and impermeable plastic undersarking. There's no obvious ventilation in loft space. One side is a brick gable end with the chimney breasts. There are no soffits and there doesn't appear to be any eave vents either.
I don't think there is enough ventilation up there, and there is a fair amount of white mould on the wood. The condensation was terrible when it was there (this coincided with having a very full house over Christmas).
The reason I noticed the condensation was because I wanted to (and since have done) fit a Nuaire Drimaster to sort condensation and poor ventilation in the house. Before installing it, I found lots of unexpected condensation on the undersarking. To address this I fitted 10 x Lap vents but in doing so noticed that the overlaps in the undersarking are quite large and not all the vents separate the entire overlap - so they probably aren't as effective as I want them to be.
Since doing that though, the loft does seem to have dried out but I'm still concerned there isn't enough air flow up there especially with the Drimaster in place.
I'd be grateful for some opinions on the best way to ventilate it. I'll probably have it converted in the not too distant future so will need to take that into account!
Options I've found:
1) Fit vent tiles
2) Fit an air brick in the gable end (there is a loose brick already between the chimney breasts, about halfway up the gable end)
3) Fit ridge vents
As mentioned, if any of them would also work with the future loft conversion, that would be great.
Any opinions much appreciated
T
Options I've found:
1) Fit vent tiles
3) Fit ridge vents
T
