- Joined
- 20 Nov 2010
- Messages
- 233
- Reaction score
- 21
- Country
Anyone know what this pipe is? It is attached to lead that comes in from the road. Is this a standard connector? As it has grey speedfit in the spur, I'm assuming that white or grey speedfit will fit into the downstream leg, as I need to replace the black pipe downstream, as it is leaking under a concrete slab somewhere (need to reroute to fix leak). Will White speedfit (screw fix) fit in the joint when I redo it?
HtH,
HtH,
