Extractor fan for bathroom.
You could, usually they are started when the light comes on, and off several minutes after u turn off the light.
Will have to look how mine is wired, it’s a timer one on a pull switch but doesn’t run on after the switch is turned off. There an isolator next to it in the loft.
Sorry to hijack the post.
To start with mine looks like it’s leaking a bit.
The wires in the unit have a jumper between 2 of the points. The isolator has 3 wires.
