Hi Guys,
So to give you an overview, 1930 semi-detached property with solid wall (no cavity) - I have had a porch built in front of the original exterior wall, door and window of the house. The porch has been built to the spec of a proper extension, insulated floor, insulated cavity wall and insulated pitched roof and composite front door.
I want to remove the original door, window and wooden frame and the brick with makes up the window sill on the right so that there can be an opening in the new porch. There is a concrete lintel that spans the opening.
I plan to cut the brick down in line with where the brick work starts on the upper right section (where the right most section of wooden window frame screws into).
My question while it may sound stupid, is the wall beneath the lintel that I wish to remove along with the wooden frame providing support to the wall above? Or is the lintel that spans each corner of the opening supporting everything, providing I follow the same brick line on the right when cutting out the wall?
Below is a picture which I appreciate isn’t great but just to give you a visual idea also.
cheers
cheers
