- Joined
- 27 Jan 2008
- Messages
- 28,952
- Reaction score
- 3,541
- Location
- Country
Is a radiator a part which need not be touched for normal operation, or a a part intended be touched for normal operation? Is the maximum temperature 70°C or 80°C?
OK this does not apply to radiators in a box using the chimney effect or fan assisted, since electrical controlled the electrical regulations do limit temperature, but is there any other regulation that limits temperature? With underfloor heating depending on surface it is around 27°C but where does it actually say that is the limit.
Tried to google it seems -18 to 70°C is the range, but can't find where it states that is the range permitted only seems to be a recommendation.
