We often install multicore SWA and it always comes with numbered white cores as standard.
Certainly not, wrong earth.No SY Gland?
Having seen the standard of RF's work in a number of pics on here, I think I'd be hard pushed to question it.Tut tut, RF, No female bush.....
yep I'm pretty sure that's what I was saying too.The inner edge of brass bushes isn't usually sharp, but even if it is, that can easily be fixed with one of these:
Female bush not required.
... I frequently find, as I'm sure RF does, that the smootheness of brass fittings is of equal standard as a female bush and therefore see no point in adding the additional ring.
Sadly no, I automatically do it reading from the end of the cable unless I'm working on existing kit which is the other way round, others seem to thing it's easier to insert the wire from the other end of the marker.Is there a standard for Panels when fitting Cable markers, I always thought they go the opposite way round to what RF has done.
is that an 'old chestnut' minefield or a BS number?Caution. You have just entered a minefield.
Is that a rule or regulation or simply the way you do it?In the pic with the terminals either side the numbers should be reading left to right on both sides. (irrespective of the exit direction of the cable).
Thats how we read a book, we don't turn the book upside down to read it.
