I wonder if anyone could help me with this one please? A month or so ago, I fitted a new bath and new taps. They're fed by 22mm copper pipes. I have those braided flexible hoses for the last foot of pipe run to each tap.
All seemed fine, but in this last week, there's been a loud hammering noise and water spurting out of the taps in time with the noise. If I open a tap gently and let a trickle of water out, all is fine. As I gradually open the tap further, the flow increases until suddenly, it hits a point where the hammering starts and the water comes out as an interrupted gush, several times per second, like a machine gun. The shockwave is transmitting along the pipes as it does so. If I open the tap still further, the knocking stops and the flow become steady again. The same thing will happen in reverse, as I close the tap. At one particular flow rate, all Hell breaks loose! Above and below that flow rate, all is fine.
It happens with the hot as well as the cold tap. We have a combi boiler, so both are at mains pressure. The pressure is pretty high - about 5.5 Bar at the tap (just under 6 Bar downstairs).
Prior to me doing this work, it was all fine with the old bath. All that has changed are the taps and the last foot of pipework. I'm just a bit puzzled why it didn't do it in the first week?
