Convert Halogen fitting to LED
Status
Not open for further replies.
If you care to scroll down that eBay listing there are other DC supplies there with shrouded terminals.
Don’t use a tens of kHz supply on lamps designed for 50/60Hz then complain they don’t last.
If I scroll down that listing there are also dishwasher tablets. What’s your point?
The product you linked to is totally unsafe and unsuitable for what the OP requires, but you’d rather continue to bleat on and on with your ridiculous fantasies rather than admit that LED lamps are not polarity sensitive and will work perfectly well when supplied from an AC electronic transformer.
The product you linked to is totally unsafe and unsuitable for what the OP requires, but you’d rather continue to bleat on and on with your ridiculous fantasies rather than admit that LED lamps are not polarity sensitive and will work perfectly well when supplied from an AC electronic transformer.[/QUOTE]
So why do they say 50/60Hz on them?
So you have no idea?
Yes I do. As I said tens of kHz typically. You obviously have no idea how switch mode power supplies work. The output frequency and mark space ratio will vary according to the loading and the input voltage.
If my grandmother had wheels she would have been a bicycle.
By the logic you are using here, if one type of lamp requires a 50/60Hz supply, a completely different one must also require the same, so all the lamps in the world must only be used with a 12V supply because that is what this very particular lamp requires?
I’ll ask you again. What is the output frequency of the electronic transformer the OP is proposing to use? Not typical anything. The specific figure.
They don't even specify whether they are AC or DC. As LEDs are DC devices one can only guess.
Alternatives in that listing do say AC/DC but not frequency.
So according to your philosophy, switched mode power supplies do not have smoothing capacitors on their outputs? To basically provide dc? Interesting...
Status
