I‘ve encountered some rot on our Victorian terrace home and I’d very much appreciate some advice.
Firstly, a couple of joists closest the front door were totally rotten- I think the old doorbell wire was acting as as a wick and directing water onto them for a hundred years or more! The house and next door were also very neglected when we purchased so probably a bit of that too. The trouble here is that the joists rest in the walls rather than on wall plates. Therefore i can’t see a way to wiggle a replacement in to the same spot. Should I bolt/resin a small wall plate in and hang via joist hangers? Any other ideas or more simple methods?
The second things is that I also discovered a rotten wooden lintel above the basement level floor. The two runs of bricks above it are also loose to the touch. This is an area where we’ve had damp problems and so I’m keen to safely replace the lintel but avoid creating damp with a concrete block or metal condensing moisture.
I’ve attached a picture of the basement door (with the lintel above) and the area where I removed a rotten joist (also above this door/ below ground floor entrance). Sorry, not sure how to orientate them the right way.
I’m sure there’s a simple solution to both these issues, I’m just not that savvy with DIY so would appreciate any insights from those with more experience.
many thanks,
Daniel
