Finally going to connect the thermal store to the woodburner. Height differences are a bit marginal- about a metre vertical on the hot across 2 metres horizontal. I'll be using a pumped loading valve so under normal circs this won't be a problem but under abnormal circs which works best- a continuous (30 degree ish) climb from woodburner to store or a short (800 mm or so) vertical out of the woodburner then about 2 metres of very gentle (2 degree) rise to store?
