Wow, still going. Maybe I should write a letter to the IET and ask them for a definitive answer?
..and the answer may have been lost in the midst of time..
That's an absolutely brilliant find...OK - I just sacrificed 20 minutes of my life to finding the answer. It's in BS EN 60669-1:2000+ A2:2008
10.7 Where cord-operated switches are provided with a pull cord, which can be fitted or
replaced by the user, they shall be so designed that it is impossible to touch live parts when
fitting or replacing the pull cord in the normal way.
Not sure that can be true. One of the tests is to load the cord with 100N for 1 min without it breaking.I still firmly believe that part of the design criteria was to enable the the cord to snap at the joint, if pulled to hard. I vaguely remember a report of child playing and becoming entangled with a pull cord round their neck and either dying or almost so.
Another probably fairly far-fetched idea, I suspect! I've just tried with a couple of current ones and, try as I may, I cannot get anything to 'snap'.I still firmly believe that part of the design criteria was to enable the the cord to snap at the joint, if pulled to hard. I vaguely remember a report of child playing and becoming entangled with a pull cord round their neck and either dying or almost so.
Yes, I was too quick. Going from the Newton being the weight of a large apple, I incorrectly estimated the weight of a large apple. Nevertheless they require a minimum strength but not a maximum.That's just over 10kg, most people who might get tangled in a hanging cord weigh quite a bit more than that.
... and, as I said, although I haven't tried supporting my weight with one (which would require me to somehow fix it to a ceiling or something), I have tried, 'on the bench', pulling as hard as I possibly can on a couple, and nothing snapped or broke - and I'm not particularly a 'weakling'.Yes, I was too quick. Going from the Newton being the weight of a large apple, I incorrectly estimated the weight of a large apple. Nevertheless they require a minimum strength but not a maximum.
Just found this: https://www.bathroom-trends.co.uk/a...room-Ceiling-Pull-Switch-FPK4-CH-29-8796.html
Not saying it's compliant or legal of course.
Well, it would do, IF the concept (of the 'string' and/or the plastic cord connectors) were as you suggest - but, as you know, I am far from convinced that such is/was the case.That rather defeats the whole concept of the string providing the user with good insulation from any live parts.
I wonder if its Class I or II - I'm not sure that one could reliably earth (all of) a 'cord' consisting of metal beads presumably strung on something non-conductive. Mind you, are we even certain that they are metal beads (rather than plastic with 'chrome paint')?As metal 'normal' switches are permitted, it would seem highly unlikely that that pull-cord would not be - assuming it is earthed properly.
Sort of, but all the recent discussion has not been about water causing a problem with the switch but, rather, water potentially turning a pull cord into a conductor (which a metal one already would be).Remember the discussion has been about water causing any problem; not the design of the switches.
