- Joined
- 26 Mar 2017
- Messages
- 4
- Reaction score
- 0
- Country
I have a 10mm existing armoured cable from CU on a 40A MCB going to workshop CU already in place. Also the shed is wired up and max draw estimate is less than 2Kw.
My question is what are the rules for adding a power circuit spur from the armoured cable junction box.
Specifically, The 10mm SWA 3 core terminates at a IP66 junction box outside the house. from there it is internal flat 10mm twin and earth to the main consumer unit on its own way with a 40mm MCB.
I would like to spur from the junction box outside the house to an external socket (x2) over a distance of about 8M from junction to last socket. I was planning to use 2.5mm external 3 core NYY-J Cable Black with appropriate glands, clipped to wall.
Firstly, must this be a 13A fused spur? and what are the other considerations for this setup as I'm having trouble finding specific info in the regs or online.
