Bathroom has the boiler in a floorstanding cupboard attached to the wall.
It was a wetroom, however, have installed a bath and shower cubicle next.
I'm preparing to build stud walls so wifey can have recessed niches along the bath, hide services etc.
I will move the floorstanding cupboard forward, build the stud wall and re-attach the cupboard to it. I will terminate the wall just inside the cupboard as the boiler is attached to the plaster. It just means the cupboard will be deeper than it looks on the outside.
Anyhow:
I've found whoever installed the boiler (in 2018) has taken a power feed from somewhere under the floor, into a switched fused spur, which is laying loose on the floor under the cupboard.
Power from here goes to a Honeywell wireless receiver, which is also laying loose on the floor. Power from this goes to the boiler.
My first question is surely this is unsafe, and both units should be screwed to the wall inside of the cupboard. Basically not on the floor of a wetroom. Are there any rules about placement within the cupboard (e.g., should they be a certain height off the floor, or, not directly under the boiler)
Second question:
Wifey, as a surprise, purchased an electric touch screen light up mirror with defogger. This is mains powered. I can route cable behind the stud wall to the cupboard (v.short run).
Can I safely daisy chain an rcd fused spur, from the existing one feeding the boiler, and it be considered "safe" for bathroom use?
Alternatively, I can run the power cable for the mirror straight down to the pantry, and connect an rcd fused spur there.
Or is the whole setup a death trap and time to pay someone to do it.
Any advice welcome.
Anyhow:
Second question:
Any advice welcome.
