Boiler combustion readings high
21 Feb 2011
Yorkshire
I'd appreciate some help with the following please:
Just had our boiler serviced and the guys have issued a warning based on the combustion readings being high.
They've stripped the unit down and cleaned the fan, which has markedly improved the readings but they say they're still too high.
They have not condemned the boiler.
So do I need a new boiler or do I see what happens when it's due its next service?
Thank you
And the boiler is.....?
What paperwork did they leave? Can you post a photo, covering personal details?
Well its pretty hard to say as not being there but assuming the hex is clear and burner pressures / flue looks ok . It could very well be that the fan is sluggish . Wouodnt even know if parts are still available on this one
Oh dear you need a better Gas engineer, that is absolute rubbish
  • Thanks
Reactions: CBW
Re-read the document. It says in big letters at the top DANGER DO NOT USE. There's a clue in that ;) but it does sound like some more diagnosis is required before deciding to scrap it
muggles, he told me that it was not dangerous but I needed to change it!
The combustion readings were much less after he'd stripped and cleaned it all.
If it was dangerous it would not be in use
What was the combustion reading's.
Should ask for a gas rating, burner pressure and condition of flame picture. Technically do not have to use flue gas analyser on standard efficiency boiler
Can you please read where you have signed? An at risk appliance needs to be turned off, unless turning it off will not remove the risk.
FFS, what a prat, he told the wife verbally and then she signed this without reading it, based on what he'd said.
So this is related to the output of the boiler going outside. He said it was better than before and it would be okay.
The notice is a warning and he didn't condemn the boiler.
FFS, what a prat....The notice is a warning and he didn't condemn the boiler.
What a prat you are indeed. The notice is a warning that your boiler is in such a poor condition that it should not be used. If it was OK, there would be no reason to issue the warning notice telling you that it's not OK. I realise this isn't the answer you want to hear, but it's the one you need to hear.
