    Dismiss Notice
Boiler combustion readings high
Discussion in 'Plumbing and Central Heating' started by gladiator, 7 Dec 2020.
  1. gladiator
    gladiator
    21 Feb 2011
    84
    Thanks Received:
    4
    Yorkshire
    Country:
    I'd appreciate some help with the following please:
    Just had our boiler serviced and the guys have issued a warning based on the combustion readings being high.
    They've stripped the unit down and cleaned the fan, which has markedly improved the readings but they say they're still too high.
    They have not condemned the boiler.
    So do I need a new boiler or do I see what happens when it's due its next service?
    Thank you
  2. Sponsored Links
  3. ianmcd
    ianmcd
    15 Aug 2010
    23,451
    Thanks Received:
    9,671
    Lanarkshire
    Country:
    sorry that doesnt make any sense, can you be more specific
  4. muggles
    muggles
    28 Oct 2005
    13,337
    Thanks Received:
    3,073
    Daventry
    Country:
    And the boiler is.....?
    What paperwork did they leave? Can you post a photo, covering personal details?
  5. gladiator
    gladiator
    21 Feb 2011
    84
    Thanks Received:
    4
    Yorkshire
    Country:
    Thanks guys. Here's a copy of the document
  6. gladiator
    gladiator
    21 Feb 2011
    84
    Thanks Received:
    4
    Yorkshire
    Country:
    Hope you can help
  7. Stadan20
    Stadan20
    21 Sep 2015
    3,420
    Thanks Received:
    854
    Wiltshire
    Country:
    Make and model of boiler ?
  8. gladiator
    gladiator
    21 Feb 2011
    84
    Thanks Received:
    4
    Yorkshire
    Country:
    Myson Apollo circa 25yrs old
  9. Stadan20
    Stadan20
    21 Sep 2015
    3,420
    Thanks Received:
    854
    Wiltshire
    Country:
    Well its pretty hard to say as not being there but assuming the hex is clear and burner pressures / flue looks ok . It could very well be that the fan is sluggish . Wouodnt even know if parts are still available on this one
  10. Sponsored Links
  11. ianmcd
    ianmcd
    15 Aug 2010
    23,451
    Thanks Received:
    9,671
    Lanarkshire
    Country:
    Oh dear you need a better Gas engineer, that is absolute rubbish
    • Thanks Thanks x 1
  12. muggles
    muggles
    28 Oct 2005
    13,337
    Thanks Received:
    3,073
    Daventry
    Country:
    Re-read the document. It says in big letters at the top DANGER DO NOT USE. There's a clue in that ;) but it does sound like some more diagnosis is required before deciding to scrap it
    • Like Like x 1
  13. gladiator
    gladiator
    21 Feb 2011
    84
    Thanks Received:
    4
    Yorkshire
    Country:
    muggles, he told me that it was not dangerous but I needed to change it!
    The combustion readings were much less after he'd stripped and cleaned it all.
    If it was dangerous it would not be in use
  14. danfre
    danfre
    6 Jan 2013
    52
    Thanks Received:
    31
    Surrey
    Country:
    What was the combustion reading's.
    Should ask for a gas rating, burner pressure and condition of flame picture. Technically do not have to use flue gas analyser on standard efficiency boiler
    • Thanks Thanks x 2
  15. CBW
    CBW
    26 Sep 2019
    9,016
    Thanks Received:
    2,404
    North
    Country:
    Can you please read where you have signed? An at risk appliance needs to be turned off, unless turning it off will not remove the risk.
    • Like Like x 1
  16. gladiator
    gladiator
    21 Feb 2011
    84
    Thanks Received:
    4
    Yorkshire
    Country:
    FFS, what a prat, he told the wife verbally and then she signed this without reading it, based on what he'd said.
    So this is related to the output of the boiler going outside. He said it was better than before and it would be okay.
    The notice is a warning and he didn't condemn the boiler.
  17. muggles
    muggles
    28 Oct 2005
    13,337
    Thanks Received:
    3,073
    Daventry
    Country:
    What a prat you are indeed. The notice is a warning that your boiler is in such a poor condition that it should not be used. If it was OK, there would be no reason to issue the warning notice telling you that it's not OK. I realise this isn't the answer you want to hear, but it's the one you need to hear.
    • Thanks Thanks x 2
Loading...
Share This Page
