It's OK, Theres nothing actually wrong there but it is quite untidy, also it would be better if each socket had a screw holding it to the cabinet.Ah, that makes a lot more sense. Thanks for your advice so far - it's really appreciated.
One of the terminal screws was pretty chewed up, so if I'm disconnecting I should probably take the opportunity to replace with new connectors. What is their proper name (a quick search for "connectors" on Screwfix throws up a lot of results!)?
Also, the included live-mains cables were quite long. I probably should have trimmed at least one of them down (but didn't). I did try to make sure it was spread out. The photo below is the worst of the three. Is it ok to leave this excess cable (if I use some more cable clips to tidy/make more secure)?
Personally I'd have moved the T&E over and cut the cable much shorter.
Maybe not as short as I show here but it gives an idea:
