Baxi 105 e - Hot water is also warming radiators
you can get these boards soaking with usually no ill affects after the hair dryer treatment but not recommended for diyers
Indeed..Hair driers have saved my bacon a few times..Amazing how little water upsets them.
Can the driver valve be left in the boiler for this repair or would it need to be removed ?
Brilliant advice from you all and very much appreciated.
Superb.
Do I have to take the whole diverter off or can I service it in place?
Again, many thanks
Andy
Hi all
So I changed the diaphragms for the front and top bits, including the springs pin type things and the nuts.
The radiators are still getting warm when the hot water is running.
Also, could someone advise me what the positions the four valve taps should be in, in everyday use.
I should have taken a photo before beginning work on it.
Mine are set as in the photo attached.
Andy
The problem isn't the diaphragms.
Remove the front DHW brass section, unscrew the large "hex" gland screwed into the front of the rear diverter section.
Replace that bit (check the Teflon gland matches exactly with the replacement...they are sometimes wrongly supplied from the cheap ebay suppliers etc) and replace the spindles/discs etc that you can get too.
No need to remove the entire diverter.
changing diaphragms is not going to fix anything for heat leeching into the heating did you not bother reading what has been put in this thread
Thanks Gasguru -
Your post was very helpful and I'll take another look at it next weekend.
I need to do a bit more reading i think.
Thanks denso13, glad they're correct.
Cheers
Andy
