Bottom of wooden door hitting jamb
10 Mar 2017
Afternoon folks,
I have two interior wooden doors with the same issue. The bottom of the door is hitting the side jamb well before the top and so you have to really pull it to close it and then off course it pops open when opened because of the pressure on it. The door havent warped so looking for advice of what i need to alter to get these to shut flush.
OK.
Loose screws are a fairly common issue.
How much gap is there between the door [on the hinge side] and the door frame? is it [fairly] even or is the gap wideR at either top or bottom of the door?
When you had the door of were there any "packers" between the hinges and the door frame, meaning very thin strips of timber or cardboard or such?
OK.
It’s a pretty even gap on the hinge side. Tested it with a bit of paper all the way down it. There was no packers on the hinges when I looked.
Have just reread your post.
You have two doors with a similar defect? are they close to each other? and do they suffer from "Heavy use" ??
Nah. They are pretty much opposite sides of the house. They are bedroom doors so light use.
If they used to close without issue and now they're not, something must have changed. If the hinges are intact, screws not loose either in the frame or the door, the easiest way to resolve is to scribe the opening side of the door and plane to remove the excess. Job done.
some photos might be informative.
Are they panelled doors? how old?
They are solid wood doors. They are only about 12 years old in a new build bungalow. Here are some pics showing the gap decreasing.
yes, they are panelled doors in varnished softwood. it is possible for old panelled doors to sag into a trapezoid shape, with the hinge stile higher than the lock stile, and the top rail sloping, but I don't see that. Have the doors and frames had an extra coat of varnish since they went in? They will expand in humid conditions, for example if you drape wet washing over radiators or have steamy showers.
I can't make out the gap. To see it, close the door fully, and stand on the inside (so you would pull the door towards you to open it). You will be able to see the knuckles of the hinges. The gap should be sufficient to run a 10p coin between the edge of the door, and the frame, and this gap should be equal all round the door. Is it? Will a £1 coin fit?
Thanks for the quick reply!
Pound coin won’t fit anywhere round the door but the 10p is a good fit for most of it. The only place it gets tight is above the handle till just below the handle. It won’t fit in the gap there.
And what's the gap like on the hinge side, and along the top?
then I don't see how it can be the "bottom of door hitting jamb"
the bit near the latch could be planed back a bit. If you have a long spirit level or something, test to see if it is the door, or the lining ("frame") that has the bulge in it. You can rub chalk on the edge of the door to show where it is rubbing.
