- Joined
- 3 Apr 2021
- Messages
- 18
- Reaction score
- 0
- Country
Hello everyone.
I have just had an outside tap fitted by a plumber.
I have a conservatory in from off the kitchen so he couldn’t put one there. as I have a boiler that leads to an outside wall he said he could put it there. Several other also said the same.
anyway he’s don’t the job and I said a good few times I want a double check valve he seems to have done a good job but has not fitted a double check valve inside the house. he said the valve is in the tap outside side. Also I read that it should be inside. I can’t find anything by the water regulations so don’t want to call him back if it’s not true. He’s gone straight out from the boiler mains pipe to outside.
Also there is no insulation on the pipe inside the wall bit. Does it need it?
Also I paid £80 other quotes were cheaper but I wanted to pay more to have a better job done. This was a New install of a tap. I wanted a proper job done that complies with water regs
Please help.
Please help.
