Extension pitched roof
15 Dec 2012
Nottingham
Hi all, we are planning on adding a pitched roof to an extension we want to build with Marley concrete tiles on it and two roof lights in it.
The total span will be about 5.5 metres.
31 degrees pitch.
Which leaves the rafters length at 3430mm and the rise 1646mm
What I wanted to ask is if we could away with no purlins and to plasterboard directly under the rafters.
Any alternatives?
Any help appreciated thanks in advance
I'm guessing you mean a mono pitch with one end against the house.
I don't see why not, just need some beefy common rafters, maybe closer spacing.
No sorry a full pitched roof
With a double pitch you need a structural ridge which is usually a steel with a timber plate stuck on top to nail the rafters to.
If it's hipped then you need a cranked steel.
You need a structural engineer to specify
Thanks very much chaps for your opinions, it's not hipped no, just a garble end with bifold doors under it.
Sounding like an engineer then if we want no joists.
Sounding expensive so probably stick with ceiling joists.
For the span (5.5m) would we still need an engineer do we think if we had a full pitched roof
Not prohibitively expensive to employ an engineer, I paid £135+VAT for the the ridge design on this one.
Yes, that's pretty good, that might be the way to go, at least I will have the detail required to move forward.
