Hi
I've got a leaking isolation valve - the type with a flat screw head. It's in a corner next to other pipes on one side, and an extractor fan on t'other. So it's not possible to use self amalgamating tape. The pipe is on the central heating circuit. And the leak is coming from the screw head itself. I've tried turning it to different positions but with no luck.
Is there some kind of putty, mastic, sealant or whatever that I could put on it to stop the leak? Or any other recommendations to stop the leak? We'll be having some plumbing work done in a few weeks time, so it can be addressed properly then. But a fix in the meantime would be great.
I have come across a product from Fernox but it says it must be applied to dry surfaces, which isn't possible here because the leak it continuously weeping.
Any help very much appreciated.
Cheers
Cheers
