Hi just looking for some recommendations for the above that are decent?
Yes sorry I always called them mini gu10’swhat is a Mini Gu10
Do you mean a 35mm lamp
That is correct. Ideally of course MR11 GU10, to avoid confusion with MR11 with another base.Think called MR11 as 11/8th inch across is just under 35 mm.
were replaced with these
So am I useful then?Sometimes its useful to have an idiot around. It stops all the smarter people from thinking the same thing.
Wrong actually, explain what the "MR" stands for, the majority of led lamps until recently are not "MR".That is correct. Ideally of course MR11 GU10, to avoid confusion with MR11 with another base.
It was less than 2 hours you had to wait…waits for unhelpful input from resident pedant.
Where does "11.42" come from? - I'm looking at 9:02 to 10:42 - which is 100 minutes, or 1.67 hours.9.02 to 11.32 is actually 2 and a half hours.
