I am building a block wall and need about 1m^3 of concrete. I know there is a number of ways to do this is buying ready mix concrete and hiring a pump the best way? How much would It likely cost?
One cube and a pump will work out costly - could be as much as £600..? Or it could be around £400 if you have reasonable prices and an understanding regular supplier.
Two tonne of gear and 13 bags of dust will likely set you back about £170 plus a days graft for two willing labourers...£250..?
Mixed a cube on Tuesday PM in a barrow took two n half hours.
Just don't mix to much at one go say 9litres ballast, litre & half cement with 0.5litre water.
That sounds promising and I like a good workout for free. My only concern is that parts of it will go off whilst I'm still filling but I guess that's not the end of the word.
You don't buy it and barrow it, I think the correct term is volumetric mixing, they come along with one of these, two wheelbarrows and mix and tip the exact amount into your trench, you just rake it level. Mine was barely any dearer than buying the materials, I think about £500 for 3 cube but that was two years ago.
