Hi
Sorry this is a two parter...
We recently got a new boiler, went from a combi back to a system boiler and tank,
The installer didn't connect up the immersion heater as "nobody uses them nowadays"
Due to one of the thermostats being DOA, he got a Worcester engineer out to check it over. who said "Aye you could just stick a plug on it"
There is a double socket above the boiler which had the tumble dryer plugged into it. It was moved up 6" to accommodate the new boiler & the tumble dryer moved a couple of feet further away to accommodate the tank so the flex no longer reaches.
I was planning to just move the socket along the wall, but as the t&e is all neatly clippe dinto place and has been painted over, I wondered about either adding a 2nd socket or splitting it into two singles. As far as I can see there are 3 double sockets in the garage that all go back to the consumer unit, but appear to each be wired directly toe a 16a breaker rather than in a ring.
So not sure if splitting adding a 2nd socket or splitting it would count as a spur off a spur?
SImilarly I'm guessing either just connecting the immersion to a 3 pin plug or to a DP isolator spurred off that socket probably isn't a good idea? Both are unlikely to be used at the same time as the main reason for wanting to connect up the immersion is to use up excess solar with an iBoost or similar, but also aware that I should take into account other folk in the house who may not remember that the two shouldn't be run at the same time.
