Yes. The certificates are readily available on line, any one can fill one in and sign it.The person signing is confirming that the work done complies with BS7671.as for the certificate - if you just need to be competent, then what, my father can just knock one up on the PC?
BUT
the certificate has a few boxes where the results of certain tests need to be entered. Which brings you back to the need for testing.
You must have forgotten. BS3036 is a standard for semi-enclosed fuses, more commonly known as rewireable fuses.another note, when I learned it, I thought it was BS3036. I presume that’s changed?
The Wiring Regulations have been in force for a L-O-N-G time, and was adopted as a standard (BS7671) by BSI in 1992.
