- Joined
- 8 May 2017
- Messages
- 10,669
- Reaction score
- 2,872
- Country
The water is tracking down the copper pipe from above , you need to follow the pipe upward to find the source.
Where does the copper pipe go when it goes up? Post a picture of above.
Andy
Is the connection at the tap connector wet or dry (where the threaded tap tail meets it)?
You tap has a drip and its running back under the tap and through the sink and down.
My advice is , new taps time.
Andy
Worth replacing flexi and tap if it's leaking. New taps come with rubber washer that sits under tap /top of sink and seals between the two.
Also get a pair of these for under the basin:
https://www.toolstation.com/split-k...Vxp-zCh1pggFqEAQYASABEgIkm_D_BwE&gclsrc=aw.ds
Andy
