Hi all,
I have to run a cable across a kitchen ceiling. Obviously the joists are all going the wrong way.
The last time I did something like this I cut holes in the ceiling plasterboard large enough to get my drill in and then bored a small hole through the centre of the joist at the edge of the room to feed the cable through.
However, I was happy to do that as I knew that the ceiling was getting re-skimmed anyway.
The new run I'm doing is in the kitchen and I was hoping to avoid a full re-skim of the ceiling.
I've seen some YouTube video showing "flexible drill bits" and wondered if anyone has used them?
Or if people use a right-angle drill or a smaller drill so that I can maybe reach up through the small downlighter holes?
Or maybe cutting the plasterboard under the joist and channeling a bit out for the cables and overlaying it with some galvanised steel for protection?
Or is there another way of doing it that I'm not aware of?
Tips / tricks / techniques will be most welcome. Thanks
