I have a 60s maisonette with a concrete floor.
The main gas feed comes out of the floor in a cupboard in the centre of my flat where it originally fed a warm air central heating. I’ve had a new boiler installed in the loft and the gas pipe is fed into the loft to feed the new boiler.
I also have a separate feed being fed into my bathroom and into my kitchen feeding my gas hob.
I want to use this cupboard to expand the size of my tiny bathroom. Therefore the main gas feed will be coming out of the floor in the bathroom.
Is it possible to easily chase the floor and reroute the gas feed so it can be fed into a new stud wall?
if not, I will need to get a new feed from the meter, up the side of my flat and into my loft and connected onto the gas pipe in my loft.
I’ll also want to get a new feed from the gas pipe in the loft chased into the wall in my kitchen to feed my hob so I can remove the 2nd feed from the meter.
How much would this likely cost?
I just need a ballpark figure so I can plan when to get the job quoted for.
I can’t see this taking more than a day for an experienced gas engineer.
