Spark from immersion heater switch
29 Aug 2011
London
I had an immersion heater switch that sparked intermittently. So I replaced it with a new one. The new one sparks even more when switching off. The new one from wickes is ASTA approved, etc.
I understand the why's of the spark. But, I still prefer no spark. Is there such a thing as a non-sparking switch? Another switch at that location was overheated once, and burnt out. Is that an indication there is something wrong with the immersion heater?
If the switch is a good quality, and wired correctly, safely, with sound connections, you can still get 'arcing', where you get a small flash showing round the switch itself.
I do not know of a switch that is guaranteed not to do this.
This may be slightly over the top, but could it be worth considering a 2-pole isolator?
Something like this:
https://www.sparkswarehouse.com/col...ducts/bg-cprsd220-rotary-isolator-2p-20a-ip65
They are significantly 'beefier' than a standard switch, and easy to turn on and off.
Edit: although it wouldn't be a straight swap, cable glands and a fused outlet would have to be considered.
The problem is, when arcing occurs, the switch contacts are damaged. This causes higher resistance within the contacts, eventually causing even more heat damage.
A destructive feedback cycle!
...and yes, it is possible that there is something wrong with the immersion!
My understanding is that arc'ing always happens with conventional switches. I am just curious if there are any non-conventional switches for domestic use. So, there aren't.
You are pulling my leg. The heater is protected by a fuse at the consumer unit. There's probably nothing wrong with it. When I asked the question, I was still thinking the broken heater overloading the switch.
Now I am thinking the heater is overloading the worn switch caused by arcing. So the heater is OK, but the worn switch has to be replaced or the diminishing contact will cause a melt down.
My understanding is that arc'ing always happens with conventional switches. I am just curious if there are any non-conventional switches for domestic use. So, there isn't.
Yes, not a conventional switch; but again as I said, there is nothing wrong with using a small industrial switch, that won't have issues with arcing, in a domestic environment.
They always do spark/arc, but the amount can vary depending on when during the 50Hz cycle the switch is triggered - worse near one of the voltage peaks. If the arc persists longer than a fraction of a second, or it can be triggered by touching the switch - that suggests the switch may be faulty or that the switch operator is using the switch wrongly. A switch should be flicked quickly with a finger tip, rather than gripped and moved gently.
Arc visibility can appear to be worse in thin or white coloured switches, plus when it is dark - brown or black plastic hides the arc better.
Well anythings possible! ;)
It will take a good while for a switch to be destroyed by arcing, so don't panic! But, yes, that could be the failure mechanism :)
Something that fits directly will be OK. We are not all builders and electricians. It would be too involved to set it up. They should make a domestic version that are more domestic looking.
Both the new and old switches are conventional white. The new one sparks more, giving the rocker piece a surround-light kind of look.
What type of switch do you currently have ,is it double pole ? Rated at 20 amp ?
Are you quite sure? Maybe cheap switches use cheap metals and wear out after 5 switches. If they do a four-pronged iridium version, that would be OK. Those are known to last 100k miles on the car.
When it is turned on and you feel the switch, does it feel warm? If not, just ignore the arc - assuming as above it is marked 20amps.
