- Joined
- 28 Dec 2021
- Messages
- 122
- Reaction score
- 6
- Country
hi all,
I have several questions regarding a simple rear extension on a terraced house and I was wondering if anyone here can help with some knowledge. we'd like to know exactly how things work before we start spending money on approvals (restrictive covenants) and drawings.
1. my house is a mid terrace as per drawing below. none of the neighbours has an extension, but there's a shared alleyway between me and neighbour on the right. my property boundary is the thick line drawn, which goes right through the middle of the alleyway once the garden starts.
the neighbour to the left doesn't share a physical wall with me for a portion at the back, their house is offset at the front.
I would like to build a standard single-storey rear extension (around 6m x 3.4m) and I'm interested in how the foundation would work. I know they should be at least 450mm wide, but I'm confused about spacing. what I really want to avoid is having an extension that "shrinks" towards the back, I just hate the concept. we want a nice, long kitchen on one single wall, in one straight line, as if it was built at the same time as the house.
what are the rules around digging the foundations exactly up to the boundary and building a continuation of my existing outer walls? am I tresspassing if I dig the foundation under the neighbour's boundary? if I am, how does a foundation up to the boundary work? do I need an offset footing or do I build 150mm inside my boundary to avoid any issues?
2. obviously, part of building the extension would be to open the wall at the rear. it will disappear entirely. I know an RSJ is needed, but I've heard something about a "goalpost" recently.
am I right in thinking that I can still use the extenal walls (+ let's say another 150mm each side) and a pad stone to install a beam, or do I need two vertical beams on each side of the house as well?
3. any tips on how to calculate the height at the back of the extemsion, where it joins the house? I would like something that looks "natural" and complies with requirements for a pitched roof.
once again, I heard something about a 20 degrees gradient, is that the rule of thumb? existing tiles are concrete and I will likely have to match the materials.
4. while there is little physical connection to the neighbours' walls on either side (at least at the back, where the extension will be), I know that theoretically and legally we share a wall. do I have anything to do with the party wall act in this case?
