On what you have there i would use a scraper you can actually get a high spot remover from refina but its not necessary in this caseWhats the best way to shave off high spots?
It looks like there are areas near the wall that might need an inch or more to smooth out the curves. Is that possible?toupret I suppose 3-4mm .
can’t comment on easy fill. never used it.
probably not with toupretIt looks like there are areas near the wall that might need an inch or more to smooth out the curves. Is that possible?
If you do what i said you wont need an inch ive repeated it 3 times now im off lolIt looks like there are areas near the wall that might need an inch or more to smooth out the curves. Is that possible?
Taking the peaks off will still leave some massive dipsIf you do what i said you wont need an inch ive repeated it 3 times now im off lol
Is that like 4mm of wet plaster each time I add a layer or 4mm total depth I can build up in layers?toupret I suppose 3-4mm .
What depth can I actually build up though?To get it to stick well, the surface will need to be well keyed.
Not an expert, but if well keyed into the existing surface, I would suggest 1" of total extra depth should not be a problem. Have you ever plastered before? Plastering a flat surface is relatively easy, when compared to what you are intending to plaster, even the experts might be struggling with that as you have found in your house. In other words - you might well end up with a worse result than you began with.
techniques etc
That crack runs along the joint of the plasterboard 45 degree section and the curved winder which I think is mesh and plaster. There are a couple of hairline cracks on the winder part tooThis is my last post on this thread just want to say you have a large crack running along the top which you have failed to mention or nobody has noticed and would need sorting before any more plaster is added here is a close up of it for the lads to look at
