- Joined
- 27 Jan 2008
- Messages
- 29,247
- Reaction score
- 3,588
- Location
- Country
I see your point, so should the pump continue until return water is cold?One could say that if the water leaving the radiator is still hot ( hotter than the air in the room ) then the radiator was not efficient at transferring heat from the water to the air in the room
My understanding is the lock shield valve is set to allow a set drop in temperature between incoming and outgoing water, since I can't find my differential thermometer I can't really set my radiators that way, I look to ensure current does not exceed target with each room, which should only happen if there is too much flow causing a hysteresis.
But seem to remember something about calculating
There is a calculation to match the advertised output of the radiator to actual output of the radiator by correcting the Δt° used in the advert to the Δt° of the home. But this must be at best a aid to selecting radiator size, as in the real home some thing will alter air flow.
This
looks grand, but in three dimensional homes, some thing some where will interrupt that flow. This was the problem with my first house and hot air heating, the fans ensured even with furniture the air was circulated, although at first glance that may seem good, what it did was remove the cold air from next to the windows so more heat passed through the single glazed windows.We get
this problem, and the debate as to if a radiator should be on an outside wall or internal wall has gone on for years, well before central heating became the norm.The solid fuel fire needed combustion air, placing it on the outside wall means combustion air can be drawn easy from outside, so with vents near the fire drafts were reduced, but in the centre of the house, less heat lost through walls, but needed high backed chairs
to stop the draft unless ducting was fitted for the combustion air.The problem is homes have changed, with double glazing and cavity wall insulation, and loft insulation and outside doors with good seals and drafts have been excluded from our homes, which also means natural air circulation.
Heat recovery units may help, but we must not forget many homes still have the option of using solid fuel, there are
room sealed stoves with external air supply, but not very common. So we have to be careful with anything blowing air outside, be it a cooker hood, tumble drier, or bathroom extractor, we don't want exhaust gases being drawn into the home. Lucky the plumber doing my shower blocked up the vent to outside, I say lucky as bees made a nest in the air brick last year, had it not been blocked up likely would have had bees in the house.
But there must be some hot water in the boiler and pipe work when the boiler switches off, and some of that heat must go outside, but with an oil boiler i.e. not modulating the heat retained in the radiators reduces the hysteresis, so the old iron radiator which held more water is likely better.
As to a modulating boiler not so sure, until the boiler reaches its lowest output it should not turn off, the TRV in each room allows just enough heat for that room, and radiators may only be at 40°C which can be a huge advantage as I found with mothers house, where sun through bay window could cause living room to over heat, so the less heat stored in the radiator the better, the more like a motor vehicle radiator they are the better, reverse to oil boiler.
Once I used the TRV to control room temperature the morning sun stopped heating room to 32°C when set to 20°C but only hit 24°C, even without a radiator the room would have likely over heated, but wanted the radiator to store as little heat as possible, so as quickly as possible when the sun came out the radiator went cold.
The big problem is getting the TRV set up to start with, and tradition was to set temperature with a wall thermostat, we still need a wall thermostat with a modulating boiler to turn off the system on warm days, mothers house there were two, one in kitchen and one in hall, so if wind caused one side of house to be cold, one would ensure heating stayed on, but the big improvement in that house was putting a TRV in the hall as well, so hall could quickly re-warm when front door opened, but not switch boiler off permanently as the TRV slowed flow rate before wall thermostat set temperature reached.
A modulating boiler should not switch off until fully modulated, the problem was there was nothing on that boiler to tell you what the output was.
