Builder didn't add cavity tray.. How to rectify?
17 Dec 2018
Getting an extension built and I noticed that the builder/ bricklayer didn't add a cavity tray
They simple installed the lintel and built up the wall above (see attached images). What I want to know is what is the best way to rectify this issue?
The first image shows the opening for the patio door. The second image is an opening for a window.
I am looking for a good solution, which would be the least disruptive (if possible).
I say this not knowing exactly what cavity tray does - but if you need it then:
While it is at this stage, remove the bricks above and redo it with the cavity tray.
Don't mess about with half assed unsuitable resolutions - do it properly.
He'll probably be OK as you say, however waterproofing costs a few £s to fit first time round but £800 or something to rectify if there is a problem. Why should the homeowner take that risk?
Great shout..
If the job is done poorly the first time, you will pay later on..
Agreed
Thanks for the help guys.
Getting an extension built and I noticed that the builder/ bricklayer didn't add a cavity tray.
Looks to me like you have a standard Catnic CN/ lintel coupled with Dritherm insulation. Any wind driven rain eventually percolating through, with be deflected back down the cavity along with the rest.
