Fixing bolt to wall
29 Aug 2011
London
I need to fix an eye bolt to the wall to use as a secondary safety anchor for an aluminium scaffold. I plan to thread a rope in the eye and tie the two rope ends to the scaffold. Neither the rope nor bolt will be under tension except in an emergency. What size and bolt type do I need. I don't know if the bricks are hollow - I suspect it is. Thanks.
That's just the eyelbolt. The threaded anchor would be more relevant - and the fixing of that anchor to the wall type. Normally m16
Yeah, it is a M16 thread, so I guess that a 20mm hole will be required.
https://www.orbitalfasteners.co.uk/...-rawl-pno-77-150-20mm-hole-diameter-required-
Instructions are here
https://www.orbitalfasteners.co.uk/products/m16-scaffold-ring-bolt
To, the OP, you will need an SDS drill, a cheap one will suffice, oh.. and a 20mm drill bit.
Open both windows and span some 4x2 construction timber (or larger) across the opening inside. Tie the scaffold to the timber through both window openings using some decent rope and knots.
Yes, that's an option. I already had that idea using an aluminium ladder inside the house as an anchor. It won't work if I need to secure it in high winds. Don't know if more winds will strike. Hence, an external fixing was wanted in case strong winds arrive in the middle of the night. I have the knots all sorted and tested - constrictors work fine.
I used mid-strength chemical anchor to hold bolts in hollow bricks by completely filling the void. That worked to hold the metal holder of a fence post. I am thinking doing the same with the eye bolt. Even if the brick is hollow, it won't matter because it will get completely filled. I could use the max strength chemical anchor.
