In a dual RCD unit we have 3 neutral bars: 2 for the RCDs and one for the unprotected devices connected to the main switch. I appreciate that there may be adaptations…
When you do a CU from scratch you can ensure that all the neutral wires match up with the position of the MCB. This is easy to follow. Unlike with the earth bar where I’ve seen (and posted) about a spurious numbering system.
But clearly not everyone is as diligent and I’ve come across CU’s where neutral wires are all over the shop. They are however, connected to the correct N bar ( from the 3 I mentioned). Whilst it’s not tidy and difficult to troubleshoot, does this have any I’ll effects?
I’d be interested to hear if you encounter this much and what you tend to do when faced with this.
Thanks in advance.
Thanks in advance.
