Why? Is it a class 1 product?And it needs to be earthed.
Probably, but I think it could depend on the batten holder?Looks like a metal lamp to me, so wouldn't that need to be earthed?
If between the metal body and the electrical wiring there are ( at least ) two layers of insulation then the metal work need not be earthed.Looks like a metal lamp to me, so wouldn't that need to be earthed?
I can sympathise with that view, although I've always been a bit doubtful about the theory in relation to 13A plugs (and other things). For the earth connection in a plug to be "the last to disconnect in the event of a hard yank" requires that there be more slack in the earth conductor than in the other two, and I'm far from convinced that such is necessarily the case with the way most people would wire such a plug!Well if it were my lamp, I'd be rewiring it with an earth connection long enough such that it would be the last to disconnect in the event of a hard yank ... just like in a 13A plug.
Yes, that's what would be required to achieve the "L breaks first and E breaks last" but, as I said, I doubt many people wire plugs like that.That requires some deliberate thought and effort from the person fitting the plug. On the few occasions when I now need to fit them, I try to ensure that the L is the core with least play in it's length and the E with the most.
Without looking to check, I think you may well be right - that would certainly make sense, but, as I've said, I'm not sure how one is meant to achieve that ...IIRC BS1363 says when wired according to the instructions earth should disconnect last.
Who knows? However, as I've implied, I don't think that the way in which we wire the plugs, even when 'following instructions' results in any more slack in the earth conductor than any of the others, does it? (and the design of many plugs is such that trying to create such slack might be somewhat of a challenge!).Whether the manufacturers actually check this is the case and whether users actually follow the instructions is another matter.
By cutting the wires to the specified length. As EFLs pic shows the live conductor has basically a straight shot to the terminal, while the neutral and earth have loops in the which can acommodate a bit of slack. A sideways pull will also likely require more force to pull the wire out of the terminal tha a straigt one.Without looking to check, I think you may well be right - that would certainly make sense, but, as I've said, I'm not sure how one is meant to achieve that
