Break down? If you are on about micro plastics, you are barking up the wrong tree.Hi. Am I the only one who doesn't like the use of running top/rain water through a plastic which is now proven to break down and leech into the water table.
'Clean rubble' lol. FFS.I agree the so called old method of using clean rubble is surely best. Yet local authorities push the use of plastic crates. It did get me thinking. The rain water falls from the sky onto plastic roofs..runs through plastic gutters..through plastic drainage. What are we thinking!
Problem is Nige, rubble fill typically has a volume of 30% where plastic crates have a volume of 95%. So, for large systems, you'd be excavating three times as much soil. Also, most systems need to be cleanable, which isn't possible for rubble filled systems. Rubble fill is ok for the average extension but for anything else plastic is usually the only option.I agree the so called old method of using clean rubble is surely best. Yet local authorities push the use of plastic crates. It did get me thinking. The rain water falls from the sky onto plastic roofs..runs through plastic gutters..through plastic drainage. What are we thinking!
So all the world boffins are wrong then. Surely everything on earth breaks down even granite? I didn't consider the actual drinking supply being plastic in years to come major issues will develop from this.Plastic doesn't break down.
No just you and your interpretation of trade and industrial plastic use.So all the world boffins are wrong then.
