I fail to see the point to this. But hear it is anywayPictures?
That's a big assumption that they have a composite output.Have you got a TV with a SCART socket still?
ISTR you could use the composite in port on that.
OR if you have a TV with composite in (a phono yellow socket) you may be able to use that to confirm if they work.
Although they appear to be missing lenses.
Indeed yes they do look old, however I recently saw some looking similar to these:Yes, a big assumption.
Going by the size of them they look old.
I was going to offer advice but Tiger.. & Lost.. beat me to it, Sparkymarka has already repeated the same.Perhaps offer some advice to the OP instead if you know of any other way?
12V DC or 24V AC, can be either due to the way AC would be converted to DC, through a bridge rectifier.At the top left there is a 12/ 24V port which looks like you insert 2 wires into it, is it 12 or 24? surely it cant be bough!
Finally at the bottom is what looks like an SD card slot, dont have an SD card to hand but if it is that then can record from it onto the card meaning you do not need the box?
This seems to be a well specced camera that can be connected to the ethernet and can record onto an SD card. Find the model number and a manual online for a better idea of its capabilities.Then on the bottom left we have what looks like an ethernet; Is that what it is? If so is it so you can wire it up to the internet and watch it somewhere ells or something?
At the top left there is a 12/ 24V port which looks like you insert 2 wires into it, is it 12 or 24? surely it cant be bough! As it would not work or blow up. Battery charger do the job? What is the proper power source for this device, dose it come from the box?
That camera is not that old ….maybe 7years old ! But again without a model number ?It will accept AC or DC anywhere between 12 and 24 volts, to power it. Polarity is not marked so it makes no difference which way you connect it.
The earth terminal is for screening the camera from interference.
It's quite an old, though high spec security camera, but without a lens, it is useless. The lens probably included a motorised iris, powered by the camera. BNC can be fed to an older TV which has a SCART socket, or Phone A/V. I dumped several of them a decade ago - things have moved on.
