Patching plastic so it is watertight
19 Aug 2010
Luton
Hi all,
I have had to drill some holes in the heat exchanger of my dishwasher in order to clean out some accumulated grease. See link:
https://www.diynot.com/diy/threads/siemens-dishwasher-e23-error.597315/post-5310232
My problem is now to seal the holes. I'm thinking to cut some squares of plastic and affix them with Araldite or some other epoxy adhesive. Can anyone advise me on the best way to go about this or suggest a better solution?
All solutions considered.
Thanks, Chris.
What is the maximum temperature the heat exchanger has to tolerate?
Thanks FM's twin. I was thinking to use a square flat bit of plastic cut from the lid of a washing tabs box fixing it to the HE with araldite. Do you think I should source a sheet of fibreglass instead? What should I use to fix it then if not araldite?
Thanks Alec. Not sure what max temp would be. Is there some high temp stuff I could use?
How about JB weld?
Ive got this stuff in the shed. Says OK up to 180 degrees, warerproof and good for plastics.
Mmm, l like your lateral thinking Nozzle.
Trouble is I don't want to obscure the water/air/fat pathway. If I could get some threaded plugs with a thread 5mm wide and no more than 2 or 3 mm deep that may work
You just cut down the fitting so it's the correct length (depth)
Nozzle
Yes that's the fella, pretty easy to use. It's 100% waterproof and should bond well with plastic. Just cut out a bit of the sheet just bigger than the holes and paint over it with the resin, repeat until there's a few layers.
HB, can you suggest a suitable adhesive?
I'm not sure what the original plastic is. How would I find out?
Any plastic welding adhesive, which is designed for the particular type of plastic, will at first dissolve the surface of the plastic, until it has evaporated. Best way to test it, is on a corner of the plastic where it will do no harm.
