Is that available to general public do you know? I've heard about it and understand it, but would be nice to have a read through.
Don't think so but caught a copy and made my own version.
Great video.Having said all that I'd take the hit if any on stainless because Ali is not looked after properly.
Does that suggest that if the aluminium boiler is regularly run at none condensing temperatures, as it would when called daily to run at 75C flow for heating an HW cylinder, that the efficiency would decline less?
Thank you, such great info again.
When I get my new boiler, I will run at low temp, so need to think about Al. Intergas use Al, I think, with some copper as well.
"we created a revolutionary aluminium and copper heat exchanger that can reach the demanded temperatures faster than any other boiler"
How is fan speed related to modulation. Is it directly proportional?
Is that the test you did the other day in response to a post on here?
When reading the fan speed, is there an easy way to convert that to output %?The fan pulls the gas from the gas valve, the faster it turns the greater the input of fuel and the advantage is it is pulling combustion air into the burner at the same ratio so fuel/air mix remains optimum.
I've been waiting eight months now for OVO to send me an IHD! They're blaming global supply chain issues, related to semi-conductors I think.There might be several minutes lag, but if you have a Smart Meter, the Indoor Display can very accurately indicate a boilers power input, if it is the only gas consumer running.
Your SS heat exchanger looks very cool.Intergas is different, it has other shortcomings (in my opinion).
The catalyst was the other post was regarding the Worcester short cycling and a facebook thread.
Something occurred to me, watching the video. You touched on this before. It says the dT between the exiting flue gases and the return water, in some other brands, can be up to 29C. So, for example, with some boilers, does this mean that if the return comes back into the boiler at something very low like 27C, the flue gases would never get below 56C? If the dew point of the water vapour in the flue gases is 55C (as often quoted), then even at that very low return temperature, there would be no condensing?
EDIT: although that dT is when running at 80/60 - presumably that makes a difference? Do you have the dT for, say, 60/40 or 50/30? And I've often wondered, what is the typical temperature of flue gases when they first hit the heat exchanger?
Great, thanks.I think it's how much of the exchanger is at a low temperature. The flue gases or water vapour that don't touch a cool surface will not be cooled so it's time, surface area, and how much surface area is cool enough. Flame temp can be 1000⁰C.
Best to get figures from manufactures literature as they present them in the best way possible. Some don't give flue temps.
