Double bank dual RCD Board
30 Mar 2015
Can all Dual RCD boards be converted to RCBO’s or are there limitations in some of these?
I currently have a double bank Wylex dual RCD board and am considering a complete switch to RCBO’s. I already have some RCBO’s in there.
Assuming this is possible, what is the best practice for extending the busbar to the second row of RCBO’s? How do you provide the Line connectivity across the two rows of Protective Devices?
Yes.
Ok.
You can buy a busbar which is long enough and replace, or
join by short length of busbar, or
join with a suitably sized wire
(people probably won't like the last suggestion but there is no reason electrically not to do it).
There won't be two rows when you have done it, will there?
Is that not the same question?
Why not?
I currently have two rows of MCB’s. There are a few RCBO’s in the first row. If I converted everything to RCBO’s, they will span two rows. I can buy two lengths of busbar, one for each row but wanted to know what’s the best practice to connect the busbars across the two rows?
or
Notwithstanding the above, how would you join two small busbars? Would one of the RCBO’s have two busbars? Is this prone to coming lose with vibrations?
Why would you want two rows?
All RCBOs would presumably not have spaces between them.
Perhaps a difference of opinion but even if there were spaces it would still be one row with provision for more RCBOs.
You will still only need one long busbar or joined ones.
There is no best practice - you could, IF you wanted, join them all with wires instead of a busbar.
Yes, two teeth in one.
Why would they vibrate or be more prone to becoming loose than one?
I currently have approximately 16 MCB’s. This will require 16 RCBO’s and they won’t fit on a single row. I will need to spill over to the second row. Am I missing something?
I was thinking of asking "Do you mean one row above the other?" - but:
I am not sure what you actually mean.
So where are you going to put them?
My consumer unit is similar to this:
This is what I mean by RCBO’s across the two rows.
How should the busbar provide a continuous link between these two rows and ultimately back to the main switch?
For what it's worth, that's what I thought he meant, and what I thought he was describing a a "dual board".
Isn’t the image I posted known as a “double bank board”?
Since it currently has two RCD’s to protect the MCB’s, isn’t that the “Dual RCD” aspect of it?
If this is an existing DB both rows are presumably powered already? picture(s) would help
Dual RCD could also describe a board with a straight run of devices with two RCDs.
But as the title says double bank, I assumed it was one row on top of the other.
Stacked, some people call it.
Ok. My mistake. I think.
More commonly "stacked" - but, yes, that's what I took you to mean
Yes, as it has a total of two RCDs, that makes it "dual RCD" in my book. However, as has been said, the two 'rows' must already be 'powered'.
Is you problem perhaps that one (probably both) of the rows is currently powered 'through an RCD' in that row (i.e. that row effectively has an 'RCD incomer') whereas, for all RCBOs, you want both rows to be powered by a direct connection to their busbars?
