- Joined
- 7 Mar 2004
- Messages
- 300
- Reaction score
- 4
- Country
I want to build a new garage which will replace an existing one and, ideally, I'd like to do it under Permitted Developmet. However, my property's layout is a bit odd because the house is side-on to the road and the existing garage sits to the front of the property, which I've assumed is the Principal Elevation. However, as the road is to the side, am I right to be able to claim the elevation facing the road is the primary elevation? I've attached an image which will hopefully illustrate the issue better than my description!
My existing garage exceeds the height limit when compared to one built under Permitted Development - can I use this as the limit for my new garage or do I have to stick with the PD limit?
My existing garage is 33 square metres. Ideally, I'd like a bigger garage of at least 50 square metres but while there's no problem with the 50% curtilage limit, is there any limit that applies to a conservation area? I'm sure I've read somewhere that there is but I can't find it on any of the "official" guidance, etc.
Thanks for any advice offered
