That and soapy water/foam shouldn't be used, it contains salt and other stuff that isn't very good for copper/brass/SSteel and can also promote flammability. The liquid that's should be used is called leak detection fluid (LDF)
Why are we testing water pipes to 6 bar but gas pipes only to 30 millibar? Maybe 6 bar of water is similar to 30 millibar of gas in terms of ability to escape? I recently read that hydrogen escapes very easily for example.
As the smallest gas atom, it can find gaps that other atoms can't fit through!
Being so small, is one of the reasons why we use He for detecting leaks (down to 10¯6 mbar!) in UHV (ultra high vacuum) systems, it's also easy to detect, has a low concentration in normal air; and unlike H2, it doesn't explode!
