Gas mains pressure and leaks
12 Feb 2015
Surrey
I had a smart meter fitted a few months ago and he tested the pipework for leaks. From memory the pressure was millibars, ie negligible, so I am wondering with so low pressure, how can you detect leaks? I presume you can sellotape over cracks in the pipes and you'd be OK?
Just because it's low pressure doesn't mean it can't leak. I assume he would use foam or soapy water on the joints he'd made. But you'd soon smell it if there were a significant leak.
That and soapy water/foam shouldn't be used, it contains salt and other stuff that isn't very good for copper/brass/SSteel and can also promote flammability. The liquid that's should be used is called leak detection fluid (LDF)
Also Promote flammability ? you mean can corrode the metal ?
Yep, as well as corrosion ... some soaps are a mix of petroleum products or animal oils and fats, so the residue left once the water has evaporated can actually be flammable in itself.
One reason why soapy water is never used to leak test on O2 bottles, some soaps can leave flammable residue that can react directly with the HP O2 and ignite. Had an Uncle that worked at BOC and the subject of leak detection came up and they used to have to use LDF too as it's chemically inert.
