I have a 1930s semi-detached with a 5-section bay window at the front. At the top front bedroom we noticed a damp patch in the ceiling of the bay window. Ah, water leak.
Had a guy in to inspect it, which we paid £300 for. Went up on a ladder, had a look at it inside and also poked around in our attic.
Sent us some photos of some tiny cracks in the lead, and a photo of a look under the lead flashing.
Photo 1 - general view
Photo 2 - tiny crack
Photo 3 - another tiny crack
Photo 4 - view under the flashing
To repair it they've quoted us another £2800, taking the total bill to over £3,000, which seems rather steep for a couple of small holes and replacing a couple of non-load bearing bits of wood.
List of their works is below. What do you think?
To lift up courses of tiles - exposing the lead and the underlay.
To remove the old cracked lead from the area.
To remove the old rotten timber from the area.
To supply and install new OSB boards to the area.
To supply and install new, treated battens for the fascia.
To supply and install new F300 flat flashing where the bay meets the pitched roof.
To supply and install new fascia trim (drip edges).
To sand it and clean the surface.
To reinforce every joiner with CSM - chopped strand mat - reinforcement between coats.
To embed CSM into the first coat and let it cure.
To sand it and clean it with acetone.
To apply the second coat and let it cure.
To apply the top coat (UV sunshine resistant).
To re-lay the original tiles back in place.
